Re: shifting rails on a farmall 300
Posted by Wardner on September 19, 2010 at 17:20:46 from (209.86.226.23):
In Reply to: shifting rails on a farmall 300 posted by jcwag on September 19, 2010 at 10:39:42:
The rails are machined cold rolled steel.
The yokes are probably forged. At any rate they are steel because they are welded to the rails.
The rail guides are formed steel.
I would not suggest that you reshape the rail pockets while the rails are still in the the tractor.
If the yokes are worn, get another set. There is too much machine work to get them right.
Check part numbers on H, 330, 340, 350, 460, 504, 606 to see what will interchange, Goto caseih.com
