The fluid to operate hitch goes through a check valve block and it requires pressue to open the check valve for lowering. The amount of pressure may be excessive due to the check valve not opening far enough on the lowering cycle or then again it may be normal. I can't tell from here. You could take the check valve block apart and examine the parts for wear or possibly cut o-rings or even leave the check ball out to see if it operates differently. Hitch will leak down without check valve in place.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
