Re: Points ignition causing alternator damage?
Posted by Janicholson on September 20, 2010 at 06:57:31 from (199.17.6.223):
In Reply to: Re: Points ignition causing alternator damage? posted by Janicholson on September 20, 2010 at 06:53:59:
In each case, it is to keep the ignition from remaining in an "ON" condition from current backfeeding the coil. This keeps the tractor from shutting off. If an alternator internal regulator failed (shorted to ground)the resistor or idiot light would prevent excessive current flow th the alt through the ignition wire. I have never seen that happen though, Jim
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
