Posted by Janicholson on September 20, 2010 at 10:02:08 from (199.17.6.223):
In Reply to: M upgrades posted by oldtanker on September 20, 2010 at 09:02:03:
If it a mid 1951 or newer M it can have a hydraulic pump installed from a SM stage2 or newer Farmall/IH tractor. Up to X50 series. It would need heavier gears in the cam drive to assure strength if older, and only M&W aftermarket pumps will work on the older bolt pattern of front engine cover. The archives here are covering this issue vwery well. To put on Powersteering, it is necessary to use either a priority valve in the new system, or a separate belt driven hydraulic pump for the steering torque generator. Jim
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
