Re: M upgrades
Posted by mkirsch on September 20, 2010 at 11:34:37 from (64.80.108.55):
In Reply to: M upgrades posted by oldtanker on September 20, 2010 at 09:02:03:
Yup.
The live pump is over $800 all by itself. There are no cheaper alternatives. Used pumps bring at least 50% of new price, and are often worn out. They are not rebuildable.
You can't get a "kit" for the power steering any more but you can piece one together. The Charlynn torque generator is over $600 all by itself.
That's $1400, and doesn't give you any of the other bits and pieces to put it all together. No valves, no hoses, no fittings, no reservoir.
$2000 just might be enough to cover it.
