Re: Farmal H pulling my hair out
Posted by Owen Aaland on September 20, 2010 at 12:00:51 from (207.13.114.85):
In Reply to: Farmal H pulling my hair out posted by Jim Becker on September 14, 2010 at 22:47:29:
Allan, I don't often disagree with your diagnostics but in this case I would make an argument for the exhaust causing the problem rather than an intake valve.
An exhaust valve not opening or one that does stay open for the proper duration will cause a more pronounced popping in the intake manifold than a problem with an intake valve. An engine can have good compression in a cylinder with a non functioning exhaust valve because air can enter through the intake but will pop when the intake opens because the compressed air is still in the cylinder when the valve opens. An intake problem will cause a loss of compression in the cylinder making it less likely to make a sharp popping noise.
