Re: IH 504 question
Posted by Weldon K on September 20, 2010 at 17:53:30 from (98.16.35.168):
In Reply to: IH 504 question posted by Keith RE on September 20, 2010 at 11:53:57:
Brake pedal lock rod. To park tractor: Latch pedals together and push them down , pull up on lock rod, it will engage a lock pawl with the ratchet on the left brake pedal. The brake pedals will lock in this position . To release the brakes, simply press the brake pedals further down and the lock will automatically fall back into the disengaged position.
I suggest that you get an Operator's Manual for your 504. Copies available here at ytmag. Left top of page under Marketplace . Will worth the $$$$
