first off, I do not believe they were rubber, I believe they were gasket material............which is what I made mine out of. Use a small ballpeen hammer (the round side), place the sheet of gasket material over the outside end of the brake drum. Using medium light blows, you will cut the gasket to fit the recess. Now, with the gasket in the recess, take the same hammer, and tap at the center where the bolt goes. Once again, you will cut the center bolt hole out.
If you happen to drive the piece of gasket cutout into the bolt hole, a simple penknife, or darning hook can be used to pull it out.
you now have a custom made gasket for the brake drum.
ps. the first cut is done with the brake drum off the axle. the bolt hole cut is done with the drum on the axle, but no bolt installed.
This post was edited by Tom Fleming at 01:17:00 09/21/10.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
