Re: Farmall 560 vs AC D19 and JD 730 Tractors
Posted by IH fan on September 20, 2010 at 21:09:35 from (70.244.98.55):
In Reply to: Farmall 560 vs AC D19 and JD 730 Tractors posted by Kevin B from Illinois on September 19, 2010 at 18:34:39:
When he asked about "pulling", I didn't think he was wanting one for a loader tractor... for a loader the 730 would suck, but for field work, I'd take the JD any day over the other two. Better hydraulics on the JD also, plus available 3 point.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
