Re: Farmall M Final Drive Rear Axle Bearing Questions
Posted by RPM1941 on September 21, 2010 at 09:57:08 from (173.25.70.110):
In Reply to: Re: Farmall M Final Drive Rear Axle Bearing Questions posted by rustred on September 18, 2010 at 20:38:06:
Wasnt worried about his use, but what about the previous owners history, believe me when I say its makes a mess in rear frame if any of these bearings fail & ball gets between bull gear & bottom of case or brake pinion gears. I worked in IH dealer for 47 years in SW Iowa where there were a lot of mounted pickers & you havent lived until changed out a broken axle or housing under tractor in field in a muddy ditch they tried to cross with a mounted picker.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
