Re: F-20 Stuck Clutch
Posted by Bill in NJ on September 21, 2010 at 10:19:06 from (4.248.95.27):
In Reply to: F-20 Stuck Clutch posted by F-20 Clutch on September 21, 2010 at 10:01:23:
Not that familiar with F20 but a clutch is a clutch. I'm assuming the clutch is stuck in the engaged position and the external linkage is free. In that case the most logical thing is the throw out bearing carrier is somehow stuck to the tube it rides on. Rust would be my suspect. If you have an access hole that you can see the carrier try to move it with a pry bar. If it doesn't move try speraying some Kroil or WD-40 or any kind od penetrating oil. Let it sit for a while and try to pry it again. If you get it to move be sure to grease the carrier. There should be a grease fitting available to do that. If the tractor hasn't run for a while it could also be some critter has built a nest in the pressure plate. If that is the case you should be able to get at the nest with a long rod and remove most of it to the point the clutch will work.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
