Re: Wiring for lights on a 300u
Posted by John T on September 21, 2010 at 15:06:19 from (66.244.97.31):
In Reply to: Wiring for lights on a 300u posted by charlie M on September 21, 2010 at 14:11:32:
12 Gauge IS PLENTY HEAVY ENOUGH for typical stock old tractor 12 volt light systems (always still subject to load and total watts), you can probably get by with 14 fine (even 16 if not many lights depends on wattage) but if you have 12 laying around I wouldnt hesitate to go ahead n use it if you had to go out and buy 14 otherwise.
John T
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
