Re: Farmall M Final Drive Rear Axle Bearing Questions
Posted by sflem849 on September 21, 2010 at 15:23:38 from (69.197.84.192):
In Reply to: Farmall M Final Drive & Rear Axle Bearing Questions posted by keithg on September 21, 2010 at 15:03:08:
DON'T CLEAN THEM IN SOLVENT AND THEN SPIN THEM WITHOUT OIL or you will be buying new bearings :) This is especially bad when you do it with the air chuck when you are blowing the solvent out bc it spins at high speed w/o lube.
