Re: siezed motor
Posted by Jeff Z. on September 21, 2010 at 19:43:33 from (72.228.48.9):
In Reply to: siezed motor posted by farmin joe on September 21, 2010 at 19:21:18:
Try soaking the cylinders with some Sea Foam mixed with some ATF and your favorite penetrating oil and hope for the best after a week or two.
Keep putting it into the cylinders every day or two because it can get buy the rings in spots.
Depending on how long it sat I would pull the head because some of the valve seats that had valves open while it sat are probaby pretty rusty.
