Re: siezed motor
Posted by 36F30 on September 21, 2010 at 19:46:20 from (71.214.215.150):
In Reply to: siezed motor posted by farmin joe on September 21, 2010 at 19:21:18:
If its stuck from sitting remove the plugs and fill the cylinders with half ATF and half acetone mixture and let them soak. It may take months to free up, patience is the key. Try hanging a weight on the hand crank to put a little pressure on it. Once it comes free then take the whole thing apart and clean and fix/rebuild it.
If its seized, as in run without oil or overheated until it stopped, tear it down and rebuild it.
