Re: siezed motor
Posted by gene bender on September 22, 2010 at 02:30:54 from (67.55.227.196):
In Reply to: Re: siezed motor posted by Jeff Z. on September 22, 2010 at 02:18:39:
It all depends on how bad the engine is stuch. I currently have an A THAT ALL YOUR MAGIC MIXES WOULD NEVER FIX. Some dummy overhauled and let sit out and get wet. You should see the rustcrud on the walls i will have to remove crank and press out sleeve and piston together. I have had a couple that were stuck and would never have been able to free up thats why i pull the head so i can see how bad the problem is.
