Re: F-20 Stuck Clutch
Posted by robgIN on September 22, 2010 at 04:48:00 from (76.208.60.73):
In Reply to: F-20 Stuck Clutch posted by F-20 Clutch on September 21, 2010 at 10:01:23:
F-20 is really easy to get clutch out. take coupler off unhook pedal linkage and the ring of bolts out of back of clutch cover and pull it off. Clutch cover has the shaft, release fork throw out brg on it. Then you can take pressure plate and disc off. Probably find rodent debris in pressure plate. You can have clutch out in 20 minutes. Unless you have a mouse nest like was in my F-30. When it finally came out the center hub of disc was seized to shaft. What a mess.
