Posted by pete 23 on September 22, 2010 at 09:57:07 from (173.87.16.222):
In Reply to: 656 Hydro Diesel posted by russfromia on September 22, 2010 at 08:02:03:
First thing to do is to cap off the fittings coming out of transmission going to the control valve. Two small steel pipes. This will eleminate all outside valves. When you do this give your self some room as you will not be able to stop tractor with the foot-n-inch valve, only the S-R (speed ratio) lever. If it pulls fwd ok with the fittings capped off you know your problem lies outside in other words in the control valve assembly. There are two capsules in there and eiether one can be the problem as they each have two seperate function circuits inside of them. If it still does not pull forward it could be several different things inside. Fwd relief valve partially stuck, check valve leaking, cracked steel lines etc. Well, you get the picture. You would need a manual to proceed to tear into it.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
