Ive always heard a full tank is best as such reduces internal condensation plus theres liquid versus air against the tanks inner surface to reduce rust/oxidation.....
I also use Sta Bil ..............
I also mix a small quantity of low ash 2 Cycle Outboard Motor Oil in my gas and Sta Bil as I believe it can leave a light film of oil residue which can reduce corrosion/oxidation (carb and tank etc)......
I run the tractors a while so the gas and Sta Bil and 2 Cycle Oil gets mixed and fills the carb but then I turn off the gas and let them die of starvation ......
I change oil before putting them to bed cuz I dont want the old oil and acids on the bearing surfaces all winter.
Batteries kept charged with a battery minder etc.
Its good to remove plugs n squirt oil down in the cylinders to keep walls n rings oil coated to reduce rust
If its a Mag I leave it where it just snapped so points are open
Of course I dont like tires sittin on earth DUH and I air them good so they dont set all winter with any creases.
For the past 4 years after Ive done all that my hand start JD B has started the first or second pull in the spring
Im sure theres MORE TIPS I forgot but the other fine gents will add to this
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
