Re: 656 Hydro Diesel
Posted by Owen Aaland on September 22, 2010 at 16:13:24 from (207.13.114.39):
In Reply to: 656 Hydro Diesel posted by russfromia on September 22, 2010 at 08:02:03:
If the snap ring that hold the centering spring on the valve comes off you will have reverse but no forward. You can usually get it to go forward by going into reverse first and then pushing the lever into the forward position.
As a first step, see if it works properly by holding the lever to the side when it is in the forward position. Wear in the lever can cause the control valve to stay in the neutral position even though you move the lever to the forward position. Since the problem is temperature related that is a likely cause of your problem.
