Re: Farmall A generator
Posted by ScottyHOMEy on September 23, 2010 at 04:38:17 from (71.241.201.113):
In Reply to: Farmall A generator posted by Dahlin on September 23, 2010 at 04:20:15:
Several small steps, all pretty simple.
First thing to check is whether you have a cutoput relay or an actaul voltage regulator. If the relay leave as is. If a regulator, you need to give it a look -- some work with either ground, some are built polarity specific. If a regulator made for neg ground you'll need to change it out.
Once past that it's all easy. Swap the wires on the terminals on the back of your ammeter so your needle will move the right way when charging. Swap the cables on your battery (NO need to drain it), then repolarize your generator, which is as simple as making a quick connection between the BAT and GEN terminals on the relay/regulator.
