Re: Short wheel base wide axle Farmall M?
Posted by D Slater on September 23, 2010 at 07:04:01 from (184.15.13.17):
In Reply to: Re: Short wheel base wide axle Farmall M? posted by mkirsch on September 23, 2010 at 05:06:03:
IH short wheel base adapter plate, part # 67959DAX. Used for short wheel base position on adjustable wide front axles with adjustable wheel base.
Alan if you have a operators manual for the M it should explain and picture the wide front. Maybe some early ones may not though.
This post was edited by D Slater at 08:48:55 09/23/10.
