Posted by pete 23 on September 23, 2010 at 10:19:51 from (173.87.16.222):
In Reply to: 706G dump valve adj. posted by Nate V. IA on September 23, 2010 at 10:11:26:
You may need a longer bolt and if it has the spring on the bolt as earlier models did, throw it away. What you are trying to achieve is that the dump valve opens when clutch is depressed so light comes on, and when you engage clutch the light should go out just before main clutch starts to pull tractor. This amounts to filling the direct drive hydraulic clutch pack ahead of main clutch engaging. The double shift is caused by the main clutch engagineg before the direct drive clutch. Should be easy to get it correct by watching the red light. Another thing, I hate those flashing red lights, much prefer steady light as some times it is in between flashes and you can interpet that as light being off. I always change the bulbs to non flashing. Just my take .
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
