Re: Alternator Conversion
Posted by M Diesel on September 23, 2010 at 11:16:48 from (12.24.61.12):
In Reply to: Alternator Conversion posted by Matt Weltz on September 23, 2010 at 02:31:48:
What Bob says about the speed problem is true. It can be hard to get enough RPM to start charging on a 1-wire. I'm going to change mine. It is a bit of a pain because the MD doesn't have an ignition switch as such. I use the touch method for now, but often forget to do it. It will start probably 50 times on a charge so you don't notice it until...
The existing lower bracket will not work but it is easy to make a replacement piece of U shaped metal out of some flat stock to fit the alternator. Drill 4 holes and away you go. I made the U a little long and shimmed the alternator to a good running position.
