Re: Farmall A generator
Posted by John T on September 23, 2010 at 13:05:51 from (66.244.97.31):
In Reply to: Re: Farmall A generator posted by Davida on September 23, 2010 at 10:16:12:
NOPE even if you change battery polarity the tractor starter STILL TURNS THE SAME DIRECTION REGARDLESS.
Tractor starters (usually series wound) utilize a wound electromagnetic field versus small lawn tractor starters that use permanent magnet fields. A small permanent magnet motor will indeed change direction if you reverse its electical connection polarity butttttttt to reverse an electromagnetic field starter you have to reverse/swap EITHER the field or armature windings......i.e. you have to change the relationship of the field versus armature (push/pull attract/repel) and if you just swap electrical polarity they dont get changed with respect to each other STILL TURNS SAME DIRECTION
Clear as mud????????
John T
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
