Re: farmall M question missing under load
Posted by rustyfarmall on September 23, 2010 at 14:29:42 from (209.152.78.140):
In Reply to: farmall M question missing under load posted by wally b on September 23, 2010 at 12:43:52:
The fuel screw is supposed to be turned a full 3 turns out initial setting, which should be sufficient for pulling your disk. If the tractor were mine, I would turn that screw in gently until it stops, and then turn it back out 3 turns. If the tractor still stumbles and misses under load, turn that screw out 1 more turn, and possibly will need 2 more turns, for a total of 5 turns out, which is the max. If that doesn't cure it, you have problems that lie a bit deeper.
