Re: 560 Wheatland hydraulics
Posted by J.J. from Afton on September 23, 2010 at 20:46:24 from (99.149.230.7):
In Reply to: 560 Wheatland hydraulics posted by Darald in Sk on September 22, 2010 at 21:19:00:
Yep the drive gear for it will not be easy to replace, you have to split between the torque tube and transmission and the torque tube and engine in order to remove the shaft so you can replace the gear.
