Farmall F-14 Clutch Release Levers
Posted by PAKEHA on September 24, 2010 at 04:10:20 from (125.239.164.106):
The three clutch release levers on my F-14 are badly worn away. Looks like someone kept using them with a seized release bearing.
Anyway, I need to rebuild them as they are like hen's teeth over here.
If you could measure and/or have the dimensions of them so I can weld a bit on the ends to build them up (the end that press against the release bearing).
Many thanks,
Adrian
third party image
