AndrewZ came through for me
Posted by Paul Shuler on September 24, 2010 at 05:37:49 from (170.29.248.3):
Hey Andrew, got the pump put on the Super C yesterday and it worked great. As soon as I started the tractor the touch control arms moved front to back and I new I was back up and running. Everything works much faster than it did with the old pump. Like a dummy I didn't check the crankcase oil level till after I had the new pump working. The oil level was about a pint over filled but that most likely came from the old pump. I'll keep an eye on it for a while to make sure it's not leaking around the o-ring. But it's a lifting son of a gun. Thank you so much.
Paul Shuler
