Re: Farmall 100 Stiff Shifter
Posted by ScottyHOMEy on September 24, 2010 at 13:08:09 from (71.241.201.113):
In Reply to: Farmall 100 Stiff Shifter posted by Larry kosin on September 24, 2010 at 09:05:21:
I'm leaning toward mkirsch's idea.
Only thought that I'd add is that the new oil could be having either a perfectly normal effect or exposing another issue that is tolerable but will ultimately require a repair.
One is that the new lube will obviously be slicker that the old, so you won't have as much friction on the input gear shaft to offset any friction generated by a dirty/sticky/or even completely clean pilot bearing/bushing. If the bearing/bushing is at all sticky, it will continue turning the driveshaft, even with the clutch pedal depressed.
The solution for that is to hold down the clutch pedal for a longer span of time before shifting, to give time for the input shaft to stop spinning. The input still spinning while the back-end gears are sitting still is what leads to what I call the classic Farmall crunch or grind when engaging in a gear.
The other side is that 3rd (not so fast) and fourth (really fast as these things go) gears spin faster than 1st and 2nd, so it takes a little more finesse to engage them. It has to do with the relative speeds of the powered vs. the driven gears are spinning. The difference in 3rd is noticably more that 1st or 2nd, but doesn't begin to compare with 4th (your "road" gear).
If you're not having a crunch or grind, it could bery well be what mkirsch suggested, in which case you'll wanna pull the cover/shifter off and clean things up and look for wear, especially on the 3rd gear side. Or for any crud that might be binding up the shifter on those gears.
