Re: overheating
Posted by RA on June 18, 2000 at 13:40:44 from (209.150.227.119):
In Reply to: overheating posted by George on June 18, 2000 at 13:08:15:
George,
I'm wondering about something. You said you screwed with the points. This could have changed your timing. Did you check your timing after you redid the points? This will make an engine run hot. I once had a tractor that the points were rough so I filed them and set them. This changed the timing enough that just running the tractor long enough to put it in the barn (2-3 min.) That the exhaust was cherry red and the engine was very hot. Just a thought. Good luck!
Post A Followup
: Re: Re: overheating
