Re: Farmall A PTO disassembly
Posted by davin on September 24, 2010 at 19:52:42 from (97.119.9.59):
In Reply to: Farmall A PTO disassembly posted by bkpigs on September 24, 2010 at 04:05:13:
I recently installed the belt pulley pto assembly on my A. The gear on the long shaft is pressed on and has a keyway. It took a gear puller to pull the gear off the shaft. There is a bolt that keeps the gear from sliding off. Hope this helps.
Davin
