Re: New (to us) Farmall Tractors
Posted by Larry W Blum Jr on September 24, 2010 at 20:41:46 from (63.97.226.5):
In Reply to: New (to us) Farmall Tractors posted by Darald in Sk on September 24, 2010 at 18:29:50:
Scotty,
Yeah, I misspoke, one of the Hs has a distributor. It is the one with the stuck engine. As for the magneto tractors, there is nothing under the rotor button but a plate with two screws. If you remove the screws the assembly comes out with a large gear, no points. Both tractors are the same that way. We found the condenser under the four screw cap with the magneto electrical field generator but no contacts there either. As I said, we expected to find contacts but so far there are none.
