Re: Farmall A PTO disassembly
Posted by Janicholson on September 24, 2010 at 21:00:56 from (67.72.98.45):
In Reply to: Farmall A PTO disassembly posted by bkpigs on September 24, 2010 at 04:05:13:
The sleeve will come out easily (usually with a block of wood from the bottom). A puller with a puck to fit the bore is needed sometimes but usually not. They are "O"ring mounted and easy to remove. Jim
