Posted by John T on September 25, 2010 at 06:15:32 from (66.244.97.31):
In Reply to: Farmall 130 Electrical posted by BohemianJon on September 25, 2010 at 05:39:31:
Shes NOT wired correct, maybe one of Bob M's diagrams is close enough to get you by??
One wire from the genny's ARM post should wire to ARM/GEN on a Voltage regulator (or Cutout Relay) and the other wire from FLD post on the genny wires to FLD terminal on a Voltage Regulator. Then the BAT terminal on a Voltage Regulator (or Cutout Relay) wires to an ammeter if it has one, otherwise it would wire eventually to the hot ungrounded battery post often to where the big battery cable attaches to a starter solenoid or switches input.
If the Gennys ARM post is connected to a battery post or battery cable etc THAT WILL DISCHARGE THE BATTERY VERY FAST when shes shut down and the genny get hot THATS VERY VERY WICKED. Theres supposed to be a cutout relay in between ARM on Genny and the battery or ammeter or big cable etc which opens upon shut down.
Get it wired correct and then run my Troubleshooting Orocedure is best I can say for now not knowing what you have there
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
