Posted by Janicholson on September 25, 2010 at 15:24:04 from (67.72.98.45):
In Reply to: Farmall 130 Electrical posted by BohemianJon on September 25, 2010 at 05:39:31:
The wiring included below will give you a diagram for an A,B, or C. YOu do need to determine if it is 12 volt, but it is probably 6 positive ground as you indicate. The voltage will not make a difference, the only difference in the diagrams will be the inclusion of a starter relay (if yours has one) but the gen will wire the same. First is from the a terminal on the gen to the voltage reg Arm terminal on regulator (10ga wire), then from the F terminal on the gen to the Fld terminal on the reg (12ga wire), then from the gen bat term to the amp gauge load side (10ga), then to the starter switch (10ga). Vr and gen need perfect metal grounds to work.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
