Posted by ScottyHOMEy on September 25, 2010 at 17:53:54 from (71.241.201.113):
In Reply to: Split a C posted by edw on September 25, 2010 at 15:01:21:
Question is where are your splitting? If between the motor and torque tube, then, as teddy52 says, there's no need to undo the clutch linkage.
If splitting the torque tube from the tranny, then yes, but just undo the linkage from the pedal to get it apart. The rest of the linkage, if you need to take it apart for any reason, will be easier to get at and see when you open it up.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
