Re: ih truck engines
Posted by mike paulson on September 25, 2010 at 18:17:41 from (98.15.178.36):
In Reply to: ih truck engines posted by ericlb on September 24, 2010 at 21:03:04:
the dt 466 engines are bullet proof. only problem i've had with them is the damn oil pans rot out, but the are easy to replace. i see them go 150k with no problems. 30 qt crankcase, its a real truck engine in and around the 30,000 pound class. cummins motors mentioned have injection pump issues, injectors stink, and you will likely be doing a head gasket along the way. also have alot of leaks around the front engine cover and i saw one throw a rod just this week at 140K.
