Posted by Tom Fleming on September 26, 2010 at 03:39:09 from (206.193.253.243):
In Reply to: H tires posted by Tyler Jackson on September 25, 2010 at 18:51:34:
Tires that are weather checked (cracked) vs. cut/punctured, are usually fine. Tires are made with an inner section that has the reinforced cords. Then the tread is applied. as long as the inner cords are solid and intact, they are fine.
As a couple of posters have already said, if they are not bulging (indication that the inner cords are cut or broken) then they are fine.
Now, if these are really old tires, and I mean from the 30's or the 40's, the tread can start to separate from the inner section. I have a F-20 that I am going to have to break down and buy tires soon. The outer tread rubber is starting to break off from dry rot. They hold air just fine, and run fine, but the exposed inner tire is going to be prone to puncture at some point.
Today's Featured Article - New Hitches For Your Old Tractor - by Chris Pratt. For this article, we are going to make the irrational and unlikely assumption that you purchased an older tractor that is in tip top shape and needs no immediate repairs other than an oil change and a good bath. To the newcomer planning to restore the machine, this means you have everything you need for the moment (something to sit in the shop and just look at for awhile while you read the books). To the newcomer that wants to get out and use the machine for field work, you may have already hit a major roadblock. That is the dreaded "proprietary hitch". With the exception of the
... [Read Article]
Latest Ad:
[More Ads]
