Re: Which Offset Tractor is Best? A - Super A - 100 - 13...
Posted by AL Farmall Boy on September 26, 2010 at 08:00:22 from (74.240.94.240):
In Reply to: Re: Which Offset Tractor is Best? A - Super A - 100 - 13... posted by CNKS on September 26, 2010 at 07:33:44:
If I am understanding correctly, "remote hydraulics", which are connections and a valve for extra hydraulic implements, were never a factory option to the best of my knowledge for this series of tractors.
The Farmall 140 (1966-1979) is my favorite because of its slightly longer hood/nose, easier steering, deluxe seat option, lighting options, key start, 12 volt alternator, and fast hitch option. I also like them because of the sheetmetal and paint scheme.
The other offset tractors can be fitted with any of these options, but the 140 came with them from the factory. I would rule out the "A" because it does not have hydraulics, and isn't compatible as well with equipment as the others are.
The 140 will be the most expensive of the 4 models, however is still the newest. We've got 4 140's (1 older style and 3 later styles) and they are great tractors.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
