Re: Which Offset Tractor is Best? A - Super A - 100 - 13...
Posted by Wardner on September 26, 2010 at 11:47:42 from (4.154.236.42):
In Reply to: Re: Which Offset Tractor is Best? A - Super A - 100 - 13... posted by Bruce Brittain on September 26, 2010 at 11:17:38:
There is always a new hydraulic bypass block for the SA and later on eBay. Around $40. You will also have to buy a valve and hoses. If I recall, the valve will have to be closed center but the bypass block instructions will have a plumbing diagram.
IH used to sell them as well. I put a similar IH block on a Cub to run a double-acting dump cart way back in the '70s.
