The original setup had a 2 way cylinder, I believe. But the original parts are going to be hard to find. You can use a diversion fitting or valve that fits under the original tubes on the reservoir and run to a spool valve and on to the rear. These valves are readily available from several sources. The reservoir will have enough capacity for small implements, however capacity can be a problem for a large implement such as a loader as Gene says. I would think it would work on a small tandem disk, etc. You can use a double acting or single acting cylinder.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
