Re: IH 444 diesel died suddenly
Posted by Jimb2 on September 26, 2010 at 12:59:46 from (99.240.236.11):
In Reply to: IH 444 diesel died suddenly posted by rongaudier on September 26, 2010 at 10:40:53:
Hi, my first guess is fuel starvation. When a Diesel injection pump is being fuel starved, the immediate reaction is to fully open the governor, thus the revving of the engine. Are your fuel filters good? Is the fuel shut OFF/ON control working properly? Had the key fallout of rod at injection pump and fuel shut OFF go to the almost OFF position. Does your 444 have a fuel lift pump on the right side of the engine with the hand pump? If it does, open the bleed screws on the injection pump and hand
pump until the fuel comes out the lower screw, then tighten it and keep pumping until the fuel comes out the upper screw and then tighten it. If you don't get fuel out of the bleed screws then there is a problem between hand pump and injection pump.
Is the crankcase filling with Diesel fuel?
Is the engine backfiring into the air cleaner?
If yes, could be the camshaft timing gear woodruff key has sheared off.
Hope this helps
JimB
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
