Posted by EDW on September 26, 2010 at 13:02:20 from (161.11.122.77):
Hello Folks; I intend to split a "C" at the tranny and torque tube. This is a first for me and even though I have a nice repair manual I am not sure what happens with the clutch shaft. Will the shaft stay with the transmission when I separate the two halves? Thanks again to all for the advice and suggestions.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
