Re: hot pressure line on 400
Posted by roger hall on September 26, 2010 at 19:48:16 from (74.126.64.154):
In Reply to: hot pressure line on 400 posted by Charles Witt on September 26, 2010 at 18:21:04:
sounds like you have an air leak or an air bubble in your intake line--take the allen screw out of the top of the pump-careful not to lose the spring in the hole--pull the fill plug out of the hydrolic resivoir--put a little air pressure into the resivoir--it will prime the pump--the lines are designed to keep fluid in the pump--it will get hot if there is no flow
