Re: farmall h head gasket
Posted by Tyler Jackson on September 27, 2010 at 04:39:24 from (68.68.93.2):
In Reply to: farmall h head gasket posted by Chris Sw. on September 26, 2010 at 18:56:02:
All you need to do is untorque the head bolts and take off the rockler assembly. Farily easy. Just be sure that you keep track of your parts. Also youll probly have to regap the valve lash. If you have a wrench and a standard screw driver it"s super easy. The spacing is .017 I believe
