Looks like a "B" to me. Supposed to be a "47, but the serial number plate is gone, so who knows. Guess someone could tell me from the engine castings.
Aftermarket 3 point is a well done "home brew". Good welding, but holes are torch cut. Picks the woods mower up like it wasn"t there.
Would someone verify that this tractor has a tall oil filter canister? I got a replacement C135 Fram cartridge, but dimensionally it doesn"t appear to be tall enough to fit tightly in a vertical position inside the outer container (looks like it is about 3/8" too short). I need to get a new brass washer as well. It"s leaking all over and making a mess.
It also appears that the 3 point is running off of a separate hydraulic system than the touch control that is used for cultivator set up(?)Where do you fill and drain this hydraulic add on???
I have got to get a shop manual for this ride.
Mr. Mulebag:
I pulled all four plugs; 1 Autolite, 3 Champions. None were the same part number. Kinda confusing, however, I understand that whoever was "plowing" with this tractor was probably just loading it with whatever plugs he/she had available in the used plug box they had in the tractor shed. Of course, this means that everything on the tractor is suspect until I can go through it in detail. I"m sure you folks here on the forum are going to be a great assistance to me in this adventure.
Is there anyway to log onto this site so when a guy goes to post he doesn"t have to enter in his handle and email each time he wants to post something? Maybe I have just overlooked the login box.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
