Re: Backlash
Posted by CNKS on September 28, 2010 at 11:23:38 from (216.144.104.128):
In Reply to: Re: Backlash posted by Janicholson on September 28, 2010 at 09:51:39:
I probably should get a dial indicator, but I am not sure I can get it positioned correctly because I don't have good access to the gears. There is simply too much in the way.
