H trans Reverse idler shaft install
Posted by dep on September 28, 2010 at 17:31:19 from (71.233.202.55):
I was reading in the I&T manual on transmission assembly and it says the reverse idler shaft bolt hole is drilled offset and needs to be properly lined to insure lube holes are lined up. Mine is not offset and looks like it wouldnt matter which way it went in. Any ideas? Its been awhile since I took it apart.
