Posted by Tyler Jackson on September 28, 2010 at 19:02:34 from (75.207.225.132):
In Reply to: farmall h sn and fuel posted by frogbert on September 28, 2010 at 18:36:04:
Mines a 46 that has never run on distilate. Got it off the original owner and he said he never did because he thought it hurt the engine because it sounded bad. So you would be ok to run just straight gas. You start on gas with the little tank then if it's the correct sediment bowl it should have 2 inlets. One from the gas tank and one from the little tank. On the bottom of the little tank it has a shut off valve so first you shut it off thn you turn on the big tank valve and itll spit and sputter when it switches over. I have an extrs tank but its shot. i picked it up off an H at a local junk yard. Also I believe it has a higher compression head to run thr kerosene
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
